SQL Error: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ')' at line 12
SELECT u.`id`,
u.`name`,
u.`gender`,
u.`reg`,
u.`sign`,
u.`posts`,
u.`sign_active`,
u.`avatar`,
u.`avatar_size`,
u.`group_id`
FROM `pmf2user` AS u
WHERE u.`id` IN ()
AND val.`field_id` = var.`id`' at line 4
SELECT var.`name`, val.`value`, val.`user_id`
FROM `pmf2user_field_value` AS val,
`pmf2user_field` AS var
WHERE val.`user_id` IN ()
