SQL Error: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ')' at line 3
SELECT *
                           FROM `pmf2attachment`
                           WHERE `post_id` IN ()
SQL Error: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ')' at line 4
SELECT u.id,
                              u.name
                       FROM `pmf2user` AS u
                       WHERE u.id IN ()
Das GoldWing-Forum - Thema: Ohne Umbauten wäre es langweilig...
